TFTP setup for netboot.xyz
CarrotCake
CarrotCake Posts: 2 image  Freshman Member
This week I changed isp and was given an EX3301-T0 which I see can assign a TFTP server.
I've built a docker container for netboot but the documentation points to needing to tell the DHCP server which files to use and where to go. How do I configure this on the router?
The only option in the gui for the router is to assign a hostname/ip for the TFTP server which I have done. ssh on the router shows a prompt of 'ZySH>' but I'm yet to find a command which will work.
Any help would be really appreciated as I'd love to get this working
  • Peter2
    Peter2 Posts: 176 image  Master Member
    You want to login to the UI for firmware upgrade via internal ftp of the device ?
  • CarrotCake
    No. I want to be able to configure the routers dhcp to point to another server and use that for pre booting.
    I think I need to be able to configure the boot files but don’t see an option.
