[New Release] True WiFi 6 - Zyxel NBG7510 AX1800 Gigabit Router
Say goodbye to the out-of-date router, meet our new ultra-high-speed and the best value AX1800 router-NBG7510. Zyxel brings NBG7510 new entry-level WiFi 6 router, loaded the latest AX technology helps focus signal strength towards your devices, significantly improve the online experience and prevent connection delays!
Learn more: https://www.zyxel.com/products_services/AX1800-WiFi-6-Gigabit-Router-NBG7510/highlights
Key Features:
1. Next-Gen WiFi 6 standard, Ultra-fast 1.8 Gbps WiFi speed
2. Increased capacity and efficiency with MU-MIMO & OFDMA to efficiently
allocate
channels while communicating with multiple devices simultaneously
3. Achieve strong, reliable WiFi coverage with Beamforming & 4
high-gain antennas
4. Easy management with Zyxel Rover App & web interface
5. Provides your kids with a safe online experience with Parental Control
6. Supports WPA3 security
Zyxel
Good morning, I think there is something wrong with this router! Last night, everything worked fine and this morning latency problem on some application. Problem that does not exist with my other network. Also when you restart the router there is no internet connection. Obliged to reconnect by cable and go to the interface. Then turn off the wifi and restart it. I don't know what else to do with this router.
-1 -
It is working well for me in my SOHO scenario.
Kind regards,
Tony
I have just updated the NBG7510 firmware to Version V1.00(ABZY.6)C0 that came out in December 2023, and it is working well for me. :-)
Happy New Year 2024.
how to enable mesh capability ? which is in the guide of the device but there is no option in the wep interface
i have two units of nbg7510 and i cant connect in mesh wireless
Hi @AhmedAli
Could you please confirm the firmware version you are currently using?
If it is not the latest version, I recommend upgrading to the V1.00(ABZY.6)C0.
You should see a "MESH" column on the right after the updateZyxel
Hi Zyxel,
Am I correct in thinking that the NBG7510 is now coming to end of its support?
see https://webservice.zyxel.com/end-of-life and below screenshot.
i.e end of development and vulnerability support ends 30th June 2024?
What is a good migration path please?
Kind regards,Tony
del
-1
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 463 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 439 News and Release
- 4.3K FAQ
- 91 Security Highlight
