Speedlink 5501 hacked? (susicious telefone calls)
mycatisblack24
mycatisblack24 Posts: 2 image  Freshman Member
My provider informed me about suspicous/expensive telefone calls.
Is my speedlink 5501 hacked?
Can I check this anyway?
  • heathercarstens
    heathercarstens Posts: 2 image  Freshman Member
    edited October 2024
    @ slope game: You should look for a list of connected devices in the router's interface. Check for any unfamiliar devices that might indicate unauthorized access.
  • mycatisblack24
    I the recents day there was no unfamilar device in the list of connected devices.
    for the older ones I'm not able to say ok or not ok to every entry.
    I made now a factory reset and changed all passwords again.
    Now I've lost a couble of menu entrys in the config menu of the 5501. Especally the entry for the firmware update.
    How can I make sure that the latest frimware is installed?
  • mMontana
    mMontana Posts: 1,506 image  Guru Member
    You bought Speedlink 5501 from a store… or was sent to you from the provider?
