USG Flex 200 internet issue
Meszike
Meszike Posts: 5 image  Freshman Member
Hello!
Internet issue. In the case of WAN1 internet, some websites do not load, but when I switch the device to WAN2 (policy route), the page loads immediately. What could be the reason for this? The content filter is turned off.
Balázs
    PeterUK Posts: 4,450 image  Guru Member
    I take it you have different ISP for WAN1 and WAN2?
  • Meszike
    Yes. If plug in direct WAN1 cable modem a laptop, the webpages opening.
    edited October 2024
    Are the WAN IP's like 192.168.0.2 or are they public IP's ?
  • Meszike
    WAN1 public ip (Vodafone Cable), WAN2_PPP: public ip (VDSL)
    So your Vodafone Cable is set to modem mode or bridge mode?
  • Meszike
    Yes, bridge mode.
    Can you test that ISP on WAN2 port?
  • Meszike
    WAN1 to WAN2 and WAN2 to WAN1?
    Yes just to rule out a bad port on the Flex
