WiFi Repeater for NWA210AX
jkeane
jkeane Posts: 4 image  Freshman Member
First Comment Sixth Anniversary
I have an NWA210AX but I need a repeater that will work with all the SSIDs the the Access Point broadcasts. Are there any appropriate Zyxel devices that can handle repeating multiple SSIDs? (I currently have three SSIDs). Thanks in advance.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    Hi @jkeane,
    I mean purchase another NWA210AX to extend the wifi signal since I'm not sure what specific function you used and is only supported by NWA210AX. You may also purchase other Zyxel AP, just need to make sure the functions you use are supported on that model. You may check the device function table on the Nebula help center to see if they support the same functions.
    Zyxel Melen
  • Zyxel_Melen
    Hi @jkeane,
    The better choice is NWA210AX since it has the same specifications and supported functions. If you want to use other models, please check the device function table on the Nebula help center to see if they support the same functions.
    Zyxel Melen
  • jkeane
    edited October 2024
    thanks, I have the NWA210AX and will continue to use it. The issue is signal strength where I would like to use an additional repeater for complete coverage at my location. Sorry I wasn’t clear in the question before.
  • Zyxel_Melen
    Hi @jkeane,
    Zyxel Melen
  • jkeane
    ok, thanks for the clarification
Nebula Tips & Tricks
