connection problems with zyxel vpn 100
Marcointegrated
Hi, when I'm connecting throught l2tp on macos over local ADSL using same subnet of VPN I'm not able to connect to servers in vpn (ping timout). The "Send all traffic over VPN" flag is set
Hi @Marcointegrated ,
You can refer to the articles to ensure that no steps were missed during the configuration process.
VPN - Configure L2TP over IPSec VPN using PSK [Stand-alone mode] – Zyxel Support Campus EMEA
VPN - Configure L2TP over IPSec for Windows, MacOS X & iPhone iOS – Zyxel Support Campus EMEA
If the issue persists, please provide the following details:
- Your scenario and network topology, so we can better understand the relationship between your macOS, the VPN100, and the server.
- Information on whether the server is blocking traffic from the macOS.
- Logs from the server when macOS couldn't ping server.
You also can provide remote session details so we can directly check your VPN and macOS setup.
Zyxel_Judy
Ok, let's fix the problem in our address class so we simplify the problem. Thank you.
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 485 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 452 News and Release
- 4.3K FAQ
- 93 Security Highlight
