WiFi Repeater for NWA210AX
Hi @jkeane,
I mean purchase another NWA210AX to extend the wifi signal since I'm not sure what specific function you used and is only supported by NWA210AX. You may also purchase other Zyxel AP, just need to make sure the functions you use are supported on that model. You may check the device function table on the Nebula help center to see if they support the same functions.
Zyxel Melen0
Hi @jkeane,
The better choice is NWA210AX since it has the same specifications and supported functions. If you want to use other models, please check the device function table on the Nebula help center to see if they support the same functions.
Zyxel Melen0 -
thanks, I have the NWA210AX and will continue to use it. The issue is signal strength where I would like to use an additional repeater for complete coverage at my location. Sorry I wasn’t clear in the question before.
Hi @jkeane,
Zyxel Melen0 -
ok, thanks for the clarification
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
