What I'm I updating too?
PeterUK
PeterUK Posts: 4,264 image  Guru Member
So I did it a registered the Flex200H to nebula at least not fully but now shows the device as registered.
So I'm on
1.21(ABWV.0)ITS-24WK35-m5760
and nebula says there is a Upgrade available but does not tell me what version I be upgrading too like is there a new version or is it V1.21(ABWV.0) still? Or that the firmware I'm on is newer?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    edited November 2024 Answer ✓
    Hi @PeterUK ,
    When devices are running the older firmware than Stable/ Latest firmware, and the Firmware type set as "Stable"/ "Latest" with a scheduled update as below:
    The latest firmware version appears on the Device tab
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @PeterUK
    Currently, the latest official firmware for the USG FLEX 200H is V1.21(ABWV.0). Since your device is running a weekly firmware version, V1.21(ABWV.0)ITS-24WK35-m5760, which differs from the official release, Nebula is showing "Upgrade available."
    The next official firmware version, V1.30, is scheduled for release in 2024 Q4.
    Zyxel_Judy
    Untitled Image
    edited October 2024
    hi Judy
    I guess what I'm asking is for nebula to show the firmware version  it will be updating too.
  • Zyxel_Judy
    Hi @PeterUK ,
    Zyxel_Judy
    Untitled Image
    edited October 2024
    Thanks I see the problem now I need the schedule upgrade version tab and it being set to to upgrade policy but I like to do it manually and had it set to ignore upgrade which does not show the a new version is out or what I be upgrading too.
  • Zyxel_Judy
    HI @PeterUK ,
    We appreciate your feedback and suggestions.
    At the time of this writing, Nebula can show you the Schedule firmware version as I mentioned above. Recognizing the potential usefulness of displaying latest firmware version in Firmware management for users, we are considering this as a potential feature for future evaluation. You can view this idea in the following section:
    Display latest firmware version in Firmware management — Zyxel Community
    Thank you for using Zyxel products and service.
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
