Flex 200H - Memory leak issue with blank pages
GiuseppeR
GiuseppeR Posts: 369  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
edited September 2024 in USG FLEX H Series
Hello everyone,
I updated to beta firmware
V1.21(ABWV.0)ITS-24WK35-m5760
but I still have memory leak issues.
As you can see my interface page is blank:
My dashboard has too much spinning wheels:
Notification page is blank:
I'm going to reboot the firewall but I would like to understand what I can do, I'm planning to deploy this unit in 15 days in production.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,159  Zyxel Employee
    Hi @GiuseppeR ,
    Thank you for granting remote access for our investigation. We will resolve this issue in the upcoming official release.
  • Zyxel_Judy
    Hi @GiuseppeR ,
    Thank you for informing us that rebooting the firewall resolved the issue.
    If the issue persists, could you please provide SSH or WAN access to your device? This will allow us to remotely investigate the problem. We're also working on reproducing the issue on our end.
  • GiuseppeR
    Hi @Zyxel_Judy
    it happened again:
    I logged on to do some packet capturing for @Zyxel_Melen and SMTP server connection tests and I saw this problem.
    As you can see this Flex 200H was online for about a week. Too short time to request a reboot for proper working to manage, for example, notifications:
    You will see a ticket opened via Nebula page to have SSH to log in
    See you soon, best regards
  • Zyxel_Judy
    Hi @GiuseppeR ,
    PeterUK Posts: 3,769  Guru Member
    edited October 2024
    and running
    cmd http-server restart
    does not help
  • Zyxel_Judy
    Hi @PeterUK ,
    As mentioned earlier, the solution will be included in the next official firmware version, 1.30, so there is no need to use the command as a workaround.
    edited October 2024
    And V1.21(ABWV.0)ITS-24WK35-m5760 does not solve the issue after 8 days uptime 😔
  • GiuseppeR
    Unfortunately no.
    I think that with Nebula 18.20 upcoming update (about a week to wait) we are going to see also 1.30 firmware availability for 200H.
    When it will be ready please reboot it remotely (it works, just one of the few functions available via the UI when it is stuck) and when the FlexH reboots (about 12-15 mins) consider a firmware upgrade of it
  • GiuseppeR
    Hello everyone,
    while waiting for a go from Zyxel engineering team with 1.30 firmware update I still have issues with pages usually after a week of working on the site:
    Recently I can highlight also a lack of "online" status on Nebula:
    while knowing for sure that the Organization is working online properly:
