VPN client-to-site settings for MacOS 15 (Sequoia)
MarkoD
MarkoD Posts: 66  Ally Member
First Answer First Comment Friend Collector Sixth Anniversary
edited October 2024 in Security
Hi, I'm currently using these settings for a working VPN connection from Windows native clients:
Gateway:
- SA Lifetime: 86400
- Negotiation mode: Main
- Proposal (enc/auth): 3DES/SHA1
- Key Group: DH2
Connection:
- SA Lifetime: 3600
- Active Protocol: ESP
- Encapsulation: Transport (L2TP/IPSec) or Tunnel (IKEv2)
- Proposal (enc/auth): AES256/SHA1
- PFS: None
These settings have proven stable and widely supported in Windows' native VPN client and work for both L2TP/IPSec and IKEv2. I now have to connect a new Mac with macOS 15 (Sequoia) via VPN and I'm looking for a minimal change to the above settings in order for the native Mac client to successfully connect.
If anyone has the working settings for the newsest MacOS, please share. I cannot find the supported protocols for Sequoia anywhere online.
Thanks!
PS: I'd like to use the native client on the Mac (or a free alternative), not a paid VPN client.
Best Answers
  • MarkoD
    For anyone interested, the native macOS 15 Sonoma VPN client works with the settings that I have posted. No need to do any adjustements, L2TP/IPSec with pre-shared key worked flawlessly.
  • Zyxel_Kay
    Hi @MarkoD
    Thank you for sharing your experience and the successful VPN settings for macOS 15 (Sonoma)!
    To confirm, the default L2TP VPN setup using the Zyxel VPN wizard can indeed work with the following encryption settings:
    • Phase 1: 3DES/SHA1/DH2
    • Phase 2: 3DES/SHA1/None
    Kay
  • Zyxel_Kay
    Hi @MarkoD
    Thank you for sharing this valuable insight!
    We've tested the following configuration for IKEv2 VPN between the USG60 and macOS 15, and it works with the native client:
    • Phase 1: AES256, SHA256, DH19
    • Phase 2: AES256, SHA256, PFS: None
    Kay
  • Caroll
    Caroll Posts: 19  Freshman Member
    Hi @MarkoD, which firewall model are you using?
  • MarkoD
  • Zyxel_Kay
    Hi @MarkoD
    Kay
  • MarkoD
    edited October 2024
    Dear @Zyxel_Kay, you can bump up security by using SHA256 instead of 3DES in Phase 2. It works for built-in clients in Windows and also Mac.
  • Zyxel_Kay
    Hi @MarkoD
    Kay
  • MatteoFF
    MatteoFF Posts: 4  Freshman Member
    Sorry ... but I entered the parameters you indicated and nothing works. I have the client-gateway connection but there is no packet traffic. I can't ping, connect to an internal website or to the NAS via SMB/AFP. Can you help me?
  • MarkoD
    @MatteoFF If you can establish the VPN connection but there is no packet flow, then you need to check your Policy Routes and/or firewall rules.
  • MatteoFF
    edited April 8
    I tried disabling "Policy Route" but it doesn't change anything. With Microsoft Windows 10/11 everything works perfectly.
    Whit IPSec IKEv2 of Mac, the connection don't start; whit Zyxel SecuExtender IPSec the connection start but there is no packet traffic. And this only happens on Mac.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,228  Zyxel Employee
    Hi @MatteoFF ,
    If you can't establish a VPN connection after updating to macOS Sonoma or macOS Sequoia, we recommend you refer to this article first.
    Why can't I establish a VPN connection after updating to macOS Sonoma? How can I resolve this issue? — Zyxel Community
    If the issue still persists after configuring according to the article, please provide your remote session information so we can help check the problem remotely.
    Zyxel_Judy
