The implicit Security Policy works for L2TP remote Client, but not for IPSec remote client
2»
  • Soeren_Hvid_DK
    Soeren_Hvid_DK Posts: 17 image  Freshman Member
    Ok, I will test again in a few hours
  • Soeren_Hvid_DK
    I managed to make an IPsec connection from 2 VM machines win10 and Win11 and get through to the lan behind the router. But from the Host computer and another physical computer, I can't get through to the router's lan, I don't know if it's the PC firewall or something else.
    When I turn on 2FA, I haven't got the authentication Captive Portal to show up with the link
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @Soeren_Hvid_DK,
    This is because Windows native VPN will not automatically pop up the authenticate page, you need to open a browser to enter the URL I mentioned manually.
    Do the "Host computer and another physical computer" connect to the IPSec VPN? Which lan interface were you trying to access? Does it enable "use VPN" button?
    Zyxel Melen
  • Soeren_Hvid_DK
    When I disable the antivirus software firewall on the Host computer and another physical computer everything works. I will investigate which TCP/UDP IP ports to allow in the user firewall.
Nebula Tips & Tricks
