What I'm I updating too?
So I did it a registered the Flex200H to nebula at least not fully but now shows the device as registered.
So I'm on
1.21(ABWV.0)ITS-24WK35-m5760
and nebula says there is a Upgrade available but does not tell me what version I be upgrading too like is there a new version or is it V1.21(ABWV.0) still? Or that the firmware I'm on is newer?
Hi @PeterUK ,
When devices are running the older firmware than Stable/ Latest firmware, and the Firmware type set as "Stable"/ "Latest" with a scheduled update as below:
The latest firmware version appears on the Device tab
Zyxel_Judy
Hi @PeterUK
Currently, the latest official firmware for the USG FLEX 200H is V1.21(ABWV.0). Since your device is running a weekly firmware version, V1.21(ABWV.0)ITS-24WK35-m5760, which differs from the official release, Nebula is showing "Upgrade available."
The next official firmware version, V1.30, is scheduled for release in 2024 Q4.
Zyxel_Judy
Hi @PeterUK ,
Zyxel_Judy
Thanks I see the problem now I need the schedule upgrade version tab and it being set to to upgrade policy but I like to do it manually and had it set to ignore upgrade which does not show the a new version is out or what I be upgrading too.
HI @PeterUK ,
We appreciate your feedback and suggestions.
At the time of this writing, Nebula can show you the Schedule firmware version as I mentioned above. Recognizing the potential usefulness of displaying latest firmware version in Firmware management for users, we are considering this as a potential feature for future evaluation. You can view this idea in the following section:
Display latest firmware version in Firmware management — Zyxel Community
Thank you for using Zyxel products and service.
Zyxel_Judy
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
