Looking for color "dark brown or black" Outdoor Access Points
Hello;
I have a customer highly concerned with ascetics. Therefore, I am looking for a architectural dark brown or black ZYXEL Nebula Access Point(s). Or, has anyone out there ever had success painting them?
I have reached out to ZYXEL without a return :(
Thank you for the input.
Damian Solovey
KAT 7 NETWORKS
Hi @DSolo ,
Currently, our Zyxel Nebula Access Points are only available in white. This design choice aims to blend with most ceiling installations, which are typically light-colored.
While we don't offer dark brown or black versions, we recommend your customer choose the strategic placement as positioning access points in less visible areas while maintaining optimal coverage.Zyxel_Judy
Hi @DSolo ,
We used some 12-inch-by-12-inch squares of black adhesive vinyl wrap which we found on amazon for this purpose, worked great! [Oracal 651 Matte Black Adhesive Craft Vinyl]
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 486 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 452 News and Release
- 4.3K FAQ
- 93 Security Highlight
