FWA710 SMS inbox
I've looked all over the internet for the answer but cannot find a way, the Manual shows SMS Inbox on the Network Setting > Broadband > Cellular SMS menu but this is not listed.
Im on the latest firmware 1.18, can anyone help? I need to log in to my SIM provider account for which they send an SMS, the location of the router is on my roof so not easy to get physical access
The Cellular SMS feature you mentioned is not supported on the Nebula FWA710. The user manual you're referring to is a general version for all Nebula mobile routers, and some features may vary depending on the specific model.
To confirm what your device supports, please refer to chapter 1.1.1 (page 19) of the manual, which details supported features. Additionally, some ISPs offer the service of resending the SMS to a designated phone number, which could be helpful in your case. You might want to check with your provider if this service is available.
Kay
Kay
Thanks Kay, I'll see if my ISP can change the number
- 441 Beta Program
- 293 Service & License
