Using MAC Address filtering on switch with Access Points connected
mkeats
mkeats Posts: 2 image  Freshman Member
Hi, hoping someone might have some advice.
I am trying to setup MAC Address filtering on a switch to limit which devices can connect.
There are two VLANs, internal network and then guest WiFi.
3 access points in use.
Would like several mobile devices to only access WiFi and several servers or workstations to allow access on internal network.
Mike
