Looking for color "dark brown or black" Outdoor Access Points
Hello;
I have a customer highly concerned with ascetics. Therefore, I am looking for a architectural dark brown or black ZYXEL Nebula Access Point(s). Or, has anyone out there ever had success painting them?
I have reached out to ZYXEL without a return :(
Thank you for the input.
Damian Solovey
KAT 7 NETWORKS
Hi @DSolo ,
Currently, our Zyxel Nebula Access Points are only available in white. This design choice aims to blend with most ceiling installations, which are typically light-colored.
While we don't offer dark brown or black versions, we recommend your customer choose the strategic placement as positioning access points in less visible areas while maintaining optimal coverage.Zyxel_Judy
Hi @DSolo ,
We used some 12-inch-by-12-inch squares of black adhesive vinyl wrap which we found on amazon for this purpose, worked great! [Oracal 651 Matte Black Adhesive Craft Vinyl]
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
