Disabling Nebula on USG LITE 60AX? Alternatives with offline configuration?
Hi!
I bought a USG LITE 60AX and was not happy to learn that apparently there's no way to configure it locally apart from very basic settings. Furthermore, NCC configuration can take multiple minutes for a change to manifest (and I don't know when, meaning I wait for a random amount of time and retry things). But worst of all, the device sends all my confidential network usage data to the internet once connected to NCC.
Before I return it and look for something else: If I disconnect the device from Nebula, will it retain all its configuration? That would mitigate at least one of the problems, though changing configuration would be an even bigger annoyance since I'd always first have to connect it to NCC again…
Which Zyxel router/firewall models can be fully configured offline? Ideally with WiFi and 2.5GbE, similar to the 60AX?
Thanks!
Hi @Decado
You're correct that the USG LITE 60AX is designed primarily for management via Nebula Control Center (NCC), as it’s intended to be a cloud-managed security router. While changes made in NCC usually take 1-2 minutes to apply, the delay you mentioned could vary based on network conditions. Typically, it should update relatively quickly.
As for your concern about disconnecting from Nebula: yes, the device will retain its configuration when disconnected from NCC. However, please note that you’ll only have access to basic settings in the local GUI, which is mainly for troubleshooting purposes. Most configuration options are available through Nebula, and removing the device from NCC will reset its configuration.
If you're looking for a model that supports full offline configuration, we currently don’t have a router that mirrors the USG LITE 60AX in both 2.5GbE and WiFi capabilities. However, you could consider the USG FLEX H series (USG FLEX 200H or higher), which supports 2.5GbE and can be fully managed locally. It does not come with built-in WiFi, so you would need to pair it with an access point for wireless functionality.
Kay
Hi @Decado
Kay
Thanks Kay, much appreciated!
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 430 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 427 News and Release
- 89 Security Highlight
