Backup config and certificates
So having done resets and now with a certificates if after you do a reset to defaults it wipes outs certificates so if you then apply your backup config the UI will not load so you must after reset load your certificates with the same file name to then load your back.
Hi @PeterUK
Thank you for your feedback! I understand your concern regarding the differences in behaviour regarding certificate retention during a factory reset compared to older models. We appreciate your input on this matter, and I will be turning this into a feature request.
You can find the idea post here:
Kay
Hi @PeterUK
The behavior you're describing depends on the type of reboot/reset you performed on your USG FLEX H firewall.
- Reboot (press 3 to 5 seconds): Reboots the device with the last saved custom settings, preserving certificates.
- Soft Reset (press 7 to 14 seconds): Restores the device to default settings.
- Factory Reset (press over 30 seconds): Resets the device to factory settings, erasing all custom configurations.
Therefore, before applying your backup configuration, check if the certificates are still present on the device. If they’ve been erased, you’ll need to import the certificates first, making sure the file names match, and then proceed with loading your backup config.
Kay
Hi @PeterUK
Kay
- 221 Nebula Ideas
- 612 USG FLEX H Series
- 53 Wireless Ideas
- 483 News and Release
