Flex 100HP fw 1.30 - errors with email config and web UI
GiuseppeR
GiuseppeR Posts: 550 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
edited October 2024 in USG FLEX H Series
Hello everyone,
I started the 1.30 update of the firewall to check its improvements, so I went to Maintenance area:
I set "Send Email" option and then the firewall showed me that error you can see.
Going to dashboard everything is broken:
I clicked OK, I got this message:
If I go to WAN status on Nebula I see a lot of micro disconnections:
I noticed similar micro disconnections on another site where I installed a Flex 200H:
Is there any issue with FlexH Series monitoring in Nebula?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @GiuseppeR ,
    Thank you for providing the information that helped us clarify and troubleshoot your case.
    Based on your private message report, we can confirm that after upgrading to firmware version V1.30(ACII.0)ITS-m6149:
    • The GUI is functioning properly
    • The backup configuration email feature is working correctly
    We can now consider this case resolved.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    edited October 2024
    Hi @GiuseppeR ,
    I attempted to reproduce the issue you reported using smtp.gmail.com as the Mail Server
    And tried sending the startup-config file.
    The test was successful - I received the USG FLEX 200H configuration in my email inbox.
    To help troubleshoot your specific case, could you please provide WAN access to your device via the private message? This would allow us to investigate and diagnose the issue directly.
    Zyxel_Judy
    Untitled Image
  • GiuseppeR
    Hello @Zyxel_Judy
    I opened a Case and sent you the privileges to access it. I'm at your disposal.
  • Zyxel_Judy
    Hi @GiuseppeR ,
    Zyxel_Judy
    Untitled Image
  • GiuseppeR
    Hello @Zyxel_Judy
    I confirm that now is working smoothly, well done 😎
