USG FLEX 500 - lan1 to lan 2 and lan2 to lan1
Hello I have a firewall usg flex 500 with lan 1 (192.168.0.0 GW 192.168.0.230) and lan 2 (192.168.33.0 GW 192.168.33.230) for both lan the GW is the firewall itself
I need to make the two lan's and consequently the clients talk by enabling ips control
I can ping the firewall from both subnets on ex: 192.168.0.190 --> 192.168.33.230 but I can't ping client to client 192.168.0.190--> 192.168.33.100
I have tried state route and policy route but to no effect. What am I missing?
You don't need to add routes, those destinations are included in "direct route".
You could look at the logs, to see if some other firewall rule blocks traffic.
I see nothing from the firewall logs.
Only if I enter a policy control (lan1 to lan2) I can see the ICMP pass as accepted even though I still receive unreachable from the client.0 -
It could be remote device that doesn't respond.
What kind of device are you unable to ping? PC, printer, etc…
likely a firewall on end device
unless you have enabled "Use IPv4 Policy Route to Overwrite Direct Route" ?with routeing rule like LAN1 next hop WAN?
is a server with dual ports 1) with the subnet 192.168.0.179 the 2) with the subnet 192.168.33.100
And I am trying to ping the second port from a client under subnet 192.168.0.x0 -
Hi @Smartmob,
It seems like your client is using Windows OS. Have you disabled the Windows firewall before testing?
And if 192.168.33.230 can ping to 192.168.33.100?
Zyxel Melen0 -
Yes, the firewall is deactivated.
Indeed it seems that from 192.168.33.230 I cannot ping the .100
but I simply set a static ip0 -
Inside 192.168.33.x LAN you have only that host (.100)?
Don't you have something other to ping?
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 481 News and Release
