need interface rate limiting
Not yet tested BWM but to really test this interface rate limiting is needed.
Also be able to limit by Mb and Kb
Hi @PeterUK
OK, thank you😉. We are investigating this issue for you. Once we resolve it, you can continue testing the Bandwidth Management (BWM) feature.
This plus I want to rate limit a bridge in and out interfaces too
OK, got it. Thanks.
also currently not able to rate limit bridge traffic
When might we see rate limiting interfaces and rate limiting of the bridge interfaces (not the bridge itself but the interfaces for the bridge) please?
With the new UI for bridge will there be a added Egress rate limiting like this with BWM?
old models can Egress rate limit interfaces in a bridge so I'm hoping the same for FLEX H
Hi @PeterUK ,
Could you share which specific ZLD model supports Egress rate limiting on individual interfaces within a bridge?
In my experience with ZLD devices, rate limits are applied to the entire bridge rather than to individual interfaces within the bridge.Are you asking for H series devices support rate limiting for bridge or individual interfaces within a bridge?
Zyxel_Judy
Hi Judy
So on old ZLD like on VPN300 I have Ge1 (WAN1) and Ge8 (DMZ) that are in a bridge br1 I set Egress rate limiting per each interface like so.
Due to V1.31 UI changes per interfaces in the bridge only show in the bridge but I would like to be able to rate limit total limit going out the interfaces in the bridge. Just checking this will be possible in the upcoming firmware.
Note: about the old ZLD the rate limiting of interface in a bridge must 1st be removed from the bridge set rate limit then add back to bridge
Hi @PeterUK ,
Currently, there are no plans to implement the egress bandwidth function for uOS devices. If you want to set bandwidth limits for the interface, we recommend using the BWM feature instead.
Zyxel_Judy
Well I'm sure there are plans to implement the egress bandwidth other wise the new uOS is a bit pointless.
Also I did try using BWM for interfaces WAN1 and DMZ that are in a bridge and it did not rate limit that way so can that be looked at in the mean time please?
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
