[NEBULA] Multi SSID
Hello everyone,
I've got a question regarding multi SSID.
An AP can handle up to 8 SSID's, but what if I want more than that. Let's say I want 10 different SSID's, I would need 2 or 3 AP's with each a couple of SSID's.
Situation with 2 AP's: AP #1 has 4 SSID's and AP #2 has 6 SSID's
Is this possible? If yes, how do I set this up in the NCC?
Kind regards,
J. Koppen
Kind regards,
J. Koppen
Hi @JKoppen,The maximum SSID number is 8 for each site, so if you need two kinds of SSID configurations (4 SSIDs and 6 SSIDs) for different AP group, I recommend to split the APs in 2 sites according to the SSIDs.
Thanks.5
Thanks.5 -
Thank you for your reply!0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
