WiFi not working
DrAHodgson
DrAHodgson Posts: 1 image  Freshman Member
edited October 2024 in Home Router
Hi, my WiFi isn't working, and these are the colours showing on the router. Can @Zyxel_CSO please advise? Thank you.
  • Liba
    Liba Posts: 218 image  Master Member
    First Comment First Answer Third Anniversary
    It looks like the wifi LED is OK, but the Internet LED is red. So I think your phone should be able to connect to wifi successfully but cannot access the Internet. Maybe you have to check your internet settings first.
