Need to set new device password NSW100-10
HummervikenITAB
in Nebula
I need to factory reset / reset password on my NSW100-10
Red alarm blinking
Nebula says device configuration status is not up to date
Terminal and web to device asks for password
My set password is not accepted, nor is 1234
The device is passing traffic but I can't manage it.
All other Nebula devices in my system works fine.
Please help
Problem solved, found the site wide password and then reset the config on the switch
How did you find the password?
- 234 Nebula Ideas
- 6.7K Security
- 723 USG FLEX H Series
- 371 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 316 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
