EX3301-T0 Mesh connection issue
revjko
revjko Posts: 1 image  Freshman Member
I have an EX3301-T0 connected via MPro Mesh to a WX3100-T0. Most of the time it works well, but the mesh connection drops out randomly. Sometimes it will stay connected for weeks, then drop out. Sometimes it lasts just a few days and drops out. To restore the connection I disable then re-enable the Mesh setup and that reconnects. Any troubleshooting suggestions?
  • BenRolfe
    BenRolfe Posts: 1 image  Freshman Member
    I'm having the exact same issue. EX3301-T0 router with 5 WX3100-T0 MPro Mesh extenders can run for weeks but will suddenly drop out and only connect to 2 extenders. I have to manually go round powering them all off and back on to get them to re-connect. Oddly, it's always the same 2 extenders that re-connect. Any help would be greatly appreciated.
  • bahecz44120
    bahecz44120 Posts: 100 image  Ally Member
    First Comment First Answer
    power off-on is a good idea to re-connect back to network. for those 2 WX3100-T0, might be considered to place other places whcih has better signal to gateway and observe if drop out would occur.
