Mesh AP's as wireless bridge
TAPTech
TAPTech Posts: 174 image  Master Member
First Comment Friend Collector Seventh Anniversary Nebula Gratitude
edited April 2021 in Nebula
We would love to see the option to use Mesh AP's as a wireless bridge.
«1
  • Zyxel_Barney
    Zyxel_Barney Posts: 85 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Security
    Hi @TAPTech
    Do you mean an option for the Nebula AP to connect two wired networks through a wireless bridge?
    Regards,
    Barney Gregorio
  • TAPTech
    Hi Barney,
    Yes, that is what I mean.  We aren't necessarily looking to bridge entire networks together, but being able to plug in one wired device to a Nebula AP that is using a Wireless backhaul would be great!
  • Zyxel_Barney
    edited March 2019
    Hi @TAPTech
    This feature will be supported before the end of 2019.
    Please look forward to the coming Nebula releases!
    Cheers,
    Barney Gregorio
  • TAPTech
    Great!  Thank you Barney.
  • TAPTech
    edited March 2020
    Hi @Nebula_Barney ,
    Any update on this? Is this available with any models yet?
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi @TAPTech
    We rearrange the schedule for some reasons, and it will be supported in June this year.
    For your reference.
    Joslyn
  • TAPTech
    Thanks for the update Joslyn. I'm looking forward to it!
  • jacob123
    jacob123 Posts: 11 image  Freshman Member
    Zyxel Certified Network Administrator - Security First Comment Fifth Anniversary
    Looking forward to use this feature :+1:
  • sebsta
    sebsta Posts: 2 image  Freshman Member
    First Anniversary
    Hello, i tried the configuration with NWA1123-AC PRO in a mesh network (Second NWA1123-AC as root)  with power adapter over the POE/Uplink Port.
    Wifi reapeating is fine, unfortunatley network over a connected Notebook (at LAN1 port) does not work.
    Is this a firmware issue in V6.25(ABHD.2) (maybe still not supported) or do i miss something else?
    Thanks for your help, best regards.
  • Zyxel_User
    Zyxel_User Posts: 1 image  Freshman Member
    Old thread, and still not implemented?!?!
Nebula Tips & Tricks
