Converted config cannot be uploaded to USG Flex 500
Hi folks,
since I converted an existing USG110 config with the zyxel converter to the USG Flex 500 enviornment I am not able to upload the file to the new USG. The USG Flex is on default factory setting with only the admin password changed. P2 and P4 is connected as given from the Quick installation guide.
My steps:
- download the startup-config from the USG110 (not encrypted)
- converted that one with the online tool of Zyxel
- rename it to "new-startup-config.conf" to avoid direkt apply
- opened an ftp to the USG Flex 500
- "cd conf"
- set the transfer to "BIN"
- put command brings me "226 unknown reason" without uploading anything
Any ideas what to do?
Hi @Charly_brown ,
Regarding your failed conversion from USG110 to USG FLEX 500, we believe the issue may be related to a version compatibility gap in V4.60.
We have manually converted the configuration file to the latest version and sent for you. Please check the Community inbox to get the configuration file.
HI @Charly_brown ,
You can refer to this guide for instructions on uploading the converted config file to the USG FLEX 500 (either via the local GUI or command line):
USG60W to USG Flex 100W configuration conversion — Zyxel Community
Hi @Zyxel_Judy , even if I removed the initial lines of the config file FTP does not provide any response and the upload via the web gui of the USG Flex does not upload the file anyway. No response or error messgae as well. The upload itself is my issue and not applying the stuff with error cleansing.
KR C
Hi @Charly_brown ,
Could you please send me the original configuration file of your USG110 via private message? We'll review it and attempt to apply it to the USG FLEX 500, then share the results with you.
Hi @Charly_brown ,
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
