NWA1302-AC product
Hi all,
my scenario is:
I have already an Access Point providing Wireless Internet
I have a Ethernet device that requires 802.3af PoE (PD, PoE Input) to be powered.
Can NWA1302-AC be used to:
1) power up the Ethenet device (NWA1302-AC had to provide PoE out, PSE, 802.3af)
2) connet the NWA1302-AC to the existing WiFi network
Is it possible?
my scenario is:
Is it possible?
Hi @pimo
Power NWA1302 specifications:- 802.3at PoE: 20W (include 7W for PoE PSE)
- 802.3af PoE: 12W (PoE PSE disabled)
And I do not imagine any situation NWA1302 could not connect to an existing Wifi network.
I hope it helps you.
Regards
Alfonso said:Hi @pimo
Regards
I have bought it, but....
unfortunately it seems it cannot be set to connect it to an existing Wireless network...
In its setting menu there is not the possibility to set it as repeater but only as Access point.
I'm very disappointed0 -
Could you share with us which AP brand you used in your existing Wireless network?
If you just want to extend the wireless environment to let the stations use the wifi without authentication again when roaming to the NWA1302, have you tried to setup the same SSID, authentication method and the same subnet on NWA1302 for the stations? It should work without setup the repeater.
Thanks.
Joslyn0 -
Dear Joslyn,
regarless of AP brand, your procedure requires to lay a cable between the AP and NWA1302-AC, this is not possible in my scenario.
I would like to set up the scenario in the above image, and it is not possible without Client Mode on NWA1302-AC (only the AP mode is present in NWA1302-AC, while in other Zyxel device there are other modes, see second image)
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
