NXC2500 not booting
Martin_Eriksson
Hi, I have a problem with an NXC2500 that doesn't start.
The first symptom was that it restarted constantly. I then tried to upgrade the firmware via ftp to see if it would solve the problem. But after the upgrade, it does not want to start.
I can enter debug mode and start file transfer through atuk but according to the manual that does not work for the NXC2500, only for the NXC5500. On the NXC2500 firmware is recovered via ftp upload. The problem is that it doesn't get that far. When I try to connect via ftp the service is not started.
Is there any firmware for NXC2500 that can be uploaded through atuk for recovery?
Error message:
MMC read: dev # 0, block # 206849, count 163839 ... 163839 blocks read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Execute Command (Load Recovery Kernel): mmc read 0 0x20000000 0xa800 0x28000
Error message:
MMC read: dev # 0, block # 43008, count 163840 ... 163840 blocks read: OK
ERROR
Enter Debug Mode
NXC2500>
NXC2500> atuk x crc
Using xmodem-1k mode...
## Ready for binary (xmodem-1k) download to 0x05000000 at 115200 bps...
Hi @Martin_Eriksson
It looks so bad ... unfortunately, it looks like a hardware failure. I would request an RMA.
Regards0 -
Hi @Martin_Eriksson
Would you like to have a try as firmware recovery?
Here is the SOP. Use atkz to set the ftp IP address on the NXC2500.
http://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=015649&lang=EN
Please let me know if it helps.
Thanks.
Joslyn0
- 601 USG FLEX H Series
- 480 News and Release
