USG20W-VPN FSCK message
When rebooting our USG20W-VPN router via the console port, I noticed this message:
/dev/mmcblk0p7: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a or -p options)
I already used the reset button on the router and then reapplied a saved config file. The above error was still reported.
How can I get rid of the above error?
Hi @Kevin_Objsys,
What happened when this log was printed? Are you able to record the logs when rebooting so we can check?
Zyxel Melen0 -
Attached is the output showing the reboot command and what followed. We've had some intermittent trouble with traffic not going in or out through the WAN. I am not sure the problem lies with the Zyxel, but I noticed this message about the file system inconsistency while rebooting and wanted to look into it.
Hi @Kevin_Objsys,
We recommand you follow the steps below to recover it first:
- Please backup your configuration.
- Please reset the USG20w-VPN to factory default.
- Please reference this FAQ to recover the db.
- Restore the original configuration.
Hope it helps.
Zyxel Melen0 -
First, note that the error I am seeing during boot up is not the same error that is mentioned in the FAQ you referenced and also my device does boot up despite the error. But, beyond that, the instructions tell me to FTP some *.db file to the router - where does that file come from?
Hi @Kevin_Objsys,
Thanks for letting me know your concerns. After checking, please take these actions first:
(1) Plug-in power cable and enter debug mode.
(2) Enter at command:
- atkz -d
- atgo
Zyxel Melen0 -
What will those commands do? Do they make any changes to the firewall, or are they purely diagnostic?
Hi @Kevin_Objsys,
The command
atkz -d
is to print more information when booting, andatgo
is to reboot the firewall.Zyxel Melen0 -
Here is the log from rebooting with the commands given. I've scrubbed potentially sensitive stuff from the log (user names, IP addresses, passwords, some address object definitions)
<file downloaded by Melen and removed for privacy reason>
Oh, and the message about file system inconsistency and running FSCK is gone now. Along the way, I updated to the latest firmware (Nov 16 just came out) and I followed your instructions for atkz and atgo twice, because the first time I failed to capture the log. So, I'm not sure what resolved the issue, but it appears to be resolved!
- 415 Beta Program
- 2.4K Nebula
- 149 Nebula Ideas
- 96 Nebula Status and Incidents
- 5.7K Security
- 264 USG FLEX H Series
- 271 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 41 Wireless Ideas
- 6.4K Consumer Product
- 249 Service & License
- 387 News and Release
- 84 Security Advisories
- 29 Education Center
- 3.5K FAQ
- 73 Security Highlight
