Submit a website to reclassification
Zyxel_Tecology
Zyxel_Tecology Posts: 5 image  Freshman Member
Since October 2024, we are having to add several websites to the Content Filter allow list, since they are categorized as Unknown and basically appear blocked to the end-user.
Is there a website for Zyxel to submit these URLs to be reclassified so we don't have to whitelist every Org in Nebula? Or a MSP Content Filter list that combines with the Site Content Filter allow list to provide a Global allow list + Site specific allow list = Site effective allow list?
  • Zyxel_Kay
    Hi @Zyxel_Tecology
    To better understand your requirements, could you let us know how many Nebula orgs/sites you’re currently managing in Nebula CC? Additionally, it would be helpful if you could share the number of entries you typically need to add to the allow list for these sites.
    Kay
  • RickyC
    RickyC Posts: 14 image  Freshman Member
    Why answer the question with a question? How many sites you need to add has nothing to do with it. The link to the service Zyxel uses to add new, or change incorrect catagories is what is being requested here. I will have to log into a Zyxel box to get it, but would have been nice to find here.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,349 image  Zyxel Employee
    We do have the report site (Link)
    Zyxel Melen
Nebula Tips & Tricks
