Unable to locate firmwares for DX3301-T0
JackZY
JackZY Posts: 10 image  Freshman Member
I'd like to update the firmware on my DX3301-T0 but the Zyxel support site for this device lists only documents, no actual firmware details/downloads.
Can anyone point me to an accessible source of the firmwares please?
JackZY
  • Peter2
    Peter2 Posts: 176 image  Master Member
    Yes, there is a fault on the regular site since some weeks !
    This link is ok :
    https://www.zyxel.com/global/en/support/download?model=DX3301-T0
  • Peter2
    This link is ok :
  • JackZY
    Many thanks for your help @Peter2 ; coincidentally yesterday I was hunting on the Zyxel site and eventually found a reference to recent firmwares for DX3301-T0, followed the references to the same place you've kindly identified. Found 3 firmwares available, downloaded and installed the most recent, and all working fine.
