XMG3927-B50A V5.17(ABMT.6)C0 G.Vector Disable?
bulldog715
bulldog715 Posts: 29 image  Freshman Member
When I using ZT Link MT992 Openreach Gfast Modem, the sync rate was 245Mbps on downstream (believed it was enabled on G.Vector) but when swap over to Zyxel XMG3927-B50A with latest firmware V5.17(ABMT.6)C0 as the router stats showing only getting 212Mbps on downstream but was showing G.Vector disable?
Can anyone advise how to enabled G.Vector on the Zyxel router for G.fast?
  • Liba
    Liba Posts: 212 image  Master Member
    First Comment First Answer Third Anniversary
    I think that maybe Zyxel XMG3927-B50A doesn't support this on this environment. it is recommended that you should ask the service provider for assistance.
