Issues with Nebula packs
Brollachan
Brollachan Posts: 10 image  Freshman Member
I have the Nebula Pro pack on my mobile router, but to get access to the router settings on a web GUI, I had to purchase Plus packs for my AP and Switch.
Now when I try to access the router settings it says I need to buy a Pro Pack to unlock this feature, although the current pack does not expire until March 2025.
Anyone able to explain what's happening?
cheers
Ricky
  • Zyxel_Kay
    Hi @Brollachan
    To access the Pro Pack features, all Nebula devices in your organization need to have a Pro Pack license. You can check the status of your organization by navigating to Organization-wide > License & Inventory > Overview in your Nebula Control Center. Since your AP and switch currently only have the Plus Pack license, your Nebula organization type will be downgraded to the Plus Pack.
    For more details about the Nebula licensing guidelines, please refer to the following post:
    https://www.zyxel.com/global/en/nebula-license-guidelines
    Kay
  • Zyxel_Kay
    Hi @Brollachan
    Kay
  • Brollachan
    To get the one feature I want, I would have to pay double this time and my previous payment was for nothing …
    All this has done, is leave me questioning my decision to try out Zyxel, considering most of these features are free with other manufactures.
    cheers
    Ricky
  • Zyxel_Kay
    edited November 2024
    Hi @Brollachan
    From your description, it sounds like you're aiming to use the Remote Configurator feature on your Nebula mobile router. Since this feature falls under the Pro Pack, it requires a Pro Pack license for all Nebula devices in your organization to maintain the Pro Pack organization level. This is part of our Nebula Control Center design and licensing policy.
    If you prefer, you can still access the Nebula Mobile Router’s web GUI through local access as an alternative to remote access.
    Kay
  • Caroll
    Caroll Posts: 19 image  Freshman Member
    @Brollachan, here’s a quick trick! Since creating extra Nebula orgs is free, you can set up another one under your account. Just register your Nebula mobile router to the new org, and you’ll get Pro features for the mobile router while keeping Plus features for your switch and AP. 🤭
  • Brollachan
    Carroll, thanks for the idea, this would work until I re-do my network 😊
    Unfortunately, in the long term, I do not see a viable way forward while using Nebula, hence using Zyxel equipment in general.
    If you buy a Pro Pack for a device, it should work for that device, but Nebula decided to only give you a conditional pack instead, and try to sell more packs you don’t want or need (why do you charge for 3rd party devices plugged into a switch or connected by Wi-Fi?)
    For me to meet the conditions to access a mobile router remotely it would cost my £513.09 annually and I still have to get a firewall and extra AP’s to complete my network.
    For a home user, your business model does not work and when a company points things out in the Terms and Conditions or Licensing Policy knowing full well no-one has the time to read/understand the amount sent out now, not forgetting the emails/text to updates on said T&C’s, then that company is only looking out for itself and has little or no interest in its customers.
    Furthermore, if as a company you do not realise that higher end network equipment is becoming more normal now for ordinary households, and the growing demands of internet access. So, assuming everyone using your equipment is a business or company and charging accordingly is a serious flaw.
    cheers
    Ricky
  • Zyxel_Kay
    Hi @Brollachan
    Thank you for taking the time to share your detailed feedback.
    We understand your perspective on Nebula’s licensing model and the challenges it presents for home users. Your insights are valuable to us, and we’ve forwarded your concerns to the relevant team for review. We’re always looking for ways to improve, and your feedback helps us better understand the needs of our users.
    Kay
Nebula Tips & Tricks
