Moving from On-Premise to Nebula
StevieG
StevieG Posts: 15 image  Freshman Member
Zyxel Certified Network Engineer Level 1 - Nebula Network Detective-New Adventure Badge First Comment Seventh Anniversary
I probably know the answer already, but would there ever be a way of converting the config from an on-premise firewall to Nebula managed firewall without loosing the settings?
I have put most of my clients firewalls in on-premise mode as Nebula in its infancy did not allow for all the functionality I wanted.
Now Nebula is becoming a lot more advanced with many features within it's configuration I was wondering how people are moving all their settings across. Do you have to configure your rules etc. from scratch again are can they be exported/imported into Nebula?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi @StevieG ,
    You're correct - there is no tool to directly transfer your on-premises firewall configurations to Nebula. You will need to reconfigure your firewall settings manually within Nebula. You can save the on-premises configuration file before registering the firewall to Nebula. After reconfiguring the firewall settings in Nebula, you can review and refine your firewall rules.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @StevieG ,
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
