Direct Support ticketing function travels through Organizations
Hello everyone,
as you open more Organizations inside Nebula, so having more tabs open each with a different Organization, could cause interference when opening a ticket from Direct Support area:
I opened OrganizationA and its support request lists (I needed to copy a previous similar Case reference).
After that I opened another tab with OrganitazionB to look into its tickets too.
So from tab (just ready) on OrganizationA I opened a ticket, explaining the issue, selecting also the right hardware having issues.
The result is that I have a Case opened in OrganizationB also if I used the other tab with OrganizationA.
Please refer to Case 241001856 (right Organization) and Case 241001847 (wrong one).
You can see also the mistake made by Direct Support with a Case open with null value as hardware (241001847)
While you can see the right one (241001856):
Hi @GiuseppeR
After reviewing this case, we’ve identified a bug affecting this function. When multiple tabs are open, the organization/site shown in the support ticket corresponds to the last tab opened rather than the active Nebula organization/site in each respective tab.
We're actively working to resolve this issue and will keep you updated with any progress. Thank you for your patience and understanding.
Kay
Hi @GiuseppeR,
This issue has been fixed. Please help to check if this issue happens again in future.
Zyxel Melen0 -
Hello @Zyxel_Melen
thanks a lot for your notification, if needed I'll update you about that issue in the future.
Have a nice day
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
