USG FLEX 100H - CPU usage 20% in idle
szn
szn Posts: 21 image  Freshman Member
Is this expected behavior that CPU utilisation is constantly around 20% for device that just sitting on the table - no devices behined, just connection to the internet? This is seen in device dashboard.
Simon
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,244 image  Zyxel Employee
    Hi @kruess & @szn,
    This is because USG FLEX H collects and statistics the traffic/process/CPU usage date in the background, which is different from the USG FLEX/ATP series, which disables those by default.
    In addition, cpu_core_list 1 & 2 are for management only. It won't affect data traffic.
    Zyxel Melen
  • Zyxel_Melen
    Hi @szn,
    This is normal. The firewall runs many feature daemons by default, so the CPU utilization will not be 0%.
    Zyxel Melen
  • kruess
    kruess Posts: 20 image  Freshman Member
    First Comment First Answer Friend Collector Fourth Anniversary
    Not really what the endusers would expect from an idle device.
    USG/ATP's with current load usually do not more than spike above 10-15% and having them really idle they are somewhere below 5% CPU usage.
    Combine these high idle usage patterns (our 100H was more around 30-35% on idle!) with the various reports of really slow or maxing out H models (even the bigger 200 & 700 H's!) and do your math…. ☠️
    PeterUK Posts: 4,268 image  Guru Member
    Or maybe the CPU is so fast they put load on it that slows it down instead of under clocking it?
  • szn
    Hi, I've checked
    show diagnostics cpu all
    and 40% utilisation on each core seems not to be normal. I've never seen this on any idle device. Is there something more to be checked?
  • Zyxel_Melen
    Hi @kruess & @szn,
    Zyxel Melen
