USG FLEX 100H - CPU usage 20% in idle
Is this expected behavior that CPU utilisation is constantly around 20% for device that just sitting on the table - no devices behined, just connection to the internet? This is seen in device dashboard.
Simon
This is because USG FLEX H collects and statistics the traffic/process/CPU usage date in the background, which is different from the USG FLEX/ATP series, which disables those by default.
In addition, cpu_core_list 1 & 2 are for management only. It won't affect data traffic.
Zyxel Melen0
Hi @szn,
This is normal. The firewall runs many feature daemons by default, so the CPU utilization will not be 0%.
Zyxel Melen0 -
Not really what the endusers would expect from an idle device.
USG/ATP's with current load usually do not more than spike above 10-15% and having them really idle they are somewhere below 5% CPU usage.
Combine these high idle usage patterns (our 100H was more around 30-35% on idle!) with the various reports of really slow or maxing out H models (even the bigger 200 & 700 H's!) and do your math…. ☠️
Or maybe the CPU is so fast they put load on it that slows it down instead of under clocking it?
Hi, I've checked
show diagnostics cpu all
and 40% utilisation on each core seems not to be normal. I've never seen this on any idle device. Is there something more to be checked?
Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
