increase IPS range
Because your on 192.168.10.1 the change to this subnet is not a problem if your IP was 192.168.9.1 then the gateway may need to be changed to 192.168.8.1 due to how subnet IP is done
So with the change you need to increase the IP pool if needed
Here is a subnet tool
yes change to 255.255.254.0 subnet will give you 192.168.10.1 - 192.168.11.254
Is this exactly what I want to do, just put the netmask to 255.255.254.0? Once this is done, do I need to do any more configuration on the firewall?
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
