SecuExtender VPN Client IPSec 2.2.0.019 not saving password. Doesn't launch 2FA page.
ChipConnJohn
ChipConnJohn Posts: 45 image  Freshman Member
Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula First Comment Fifth Anniversary
I have a lot of Windows SecuExtender Clients out there and they work fine. Just installed on a MacBook running Ventura and it's hobbled??
  • I enter the credentials under EAP and click Configuration→Save.
    • It doesn't save the credentials. When I try the connection fails on EAP.
    • However, if I check EAP Popup and enter the credentials it connects.
  • There is no place to have the client launch the 2FA webpage for users to enter their Google Authentication code??
Am I missing something? I have all my windows users setup with complex stored passwords and then use Google Auth to authenticate them. Super easy and has good security. This Mac client is a mess.
If this is hobbled, anyone know of another VPN client that can save the username/password and lauch a webpage on connection so I can have people enter their 2FA codes?
  • ChipConnJohn
    Also, the Get Config from Server fails with the Mac client as well. The Windows version works fine. Had to create a config file on the Windows machine and import into the Mac.
  • Zyxel_Cooldia
    Hi @ChipConnJohn ,
    THanks for feedback. We are checking this issue. please wait for my update.
  • Zyxel_Cooldia
    Hi @ChipConnJohn ,
    At current design, the MAC SecuExtender VPN Client does not support web page launch, so I will raise a Feature request. Please open a browser and type URL manually for 2 factor authorization temporarily. As for password saving, could you please help to confirm it again, i can save passwords in MAC SecuExtender VPN Client.
  • ChipConnJohn
    I was able to save passwords. You have to click into another field before saving or the password isn't saved.
    On the whole, the system is clunky on a Mac. There is no Menu bar icon, so using the Systems VPN, but that requires several click a to create the connection. Then people have to launch the 2FA page manually.
  • Zyxel_Cooldia
    edited March 2023
    Hi @ChipConnJohn ,
    I have reaised it as FRQ, and this feature will be avabile in 2023/Q4.
  • ez_
    ez_ Posts: 4 image  Freshman Member
    we are in 2024/Q4, is this feature coming soon (launche a webpage) ?
    Thanks for your response.
  • valerio_vanni
    valerio_vanni Posts: 157 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    Have you tried to set the url in "when tunnel is opened" script?
