Configure the switch to perform DHCP service in a VLAN
Stelian
Stelian Posts: 3  Freshman Member
Hello everyone!
I have a Zyxel GS1920-24.
I want to configure the switch to perform DHCP service in a VLAN as in the following link -
How to configure the switch to perform DHCP service in a VLAN — Zyxel Community
But I can't configure the DHCP service.
Any ideas why or how I can do this?
I don't have the same option as in the link above.
Do I need to do a firmware update?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    edited November 2024 Answer ✓
    Hi @Stelian ,
    According to the documentation, we mentioned that only L3 Switch models (3800 series, and 4600 series) support the DHCP Server function.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @Stelian ,
    Zyxel_Judy
    Untitled Image
  • Stelian
    Hi @Zyxel_Judy
    But does Zyxel USG FLEX 100 "know" how to manage VLAN's ?
    Does it have a DHCP server to allocate IPs for VLAN's ?
    PeterUK Posts: 4,036  Guru Member
    yes the FLEX 100 does VLAN with DHCP server
  • Zyxel_Judy
    Hi @Stelian ,
    The USG FLEX 100 can function as a DHCP server. It belongs to Zyxel's firewall series, not the switch series.
    If you have both a USG FLEX 100 and a GS1920-24, you can:
    1. Configure the USG FLEX 100 as a DHCP server for your desired VLANs
    2. Set up the corresponding VLAN configurations on the GS1920-24 switch
    Zyxel_Judy
    Untitled Image
