SSL inspection
weite
weite Posts: 33 image  Freshman Member
First Comment Eighth Anniversary
We use two USG Flex 200 H and on both devices we have problems with SSL inspection.
The problem is that the websites load extremely slowly. Some pages not at all. I don't know whre I can make a mistake because the settings are simple.
Is here someone who have the same problems. Is this a bug of the firmware? We use the V1.30(ABWV.1)
    PeterUK Posts: 4,446 image  Guru Member
    Guess its still a problem from when I tested it
    SSL Inspection not running well — Zyxel Community
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,347 image  Zyxel Employee
    Hi @weite ,
    To better assist you, please let us know:
    • Are all websites loading extremely slowly or failing to load?
    • If only specific websites are affected, please share which pages are experiencing issues.
    Zyxel_Judy
    Untitled Image
  • weite
    This is short to answer. All websites are loading extremely slowly and break down.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @weite,
    I would like to clarify:
    1. Does this issue happen after upgrading to V1.30(ABWV.1)?
    2. Does this issue happen when you also enable the UTM services?
    3. To have a further investigation, can I ask for a remote PC that connects to the USG FLEX H so we can check this issue? If you can provide it, please send the remote PC information to me in a private message. Thanks.
    Zyxel Melen
  • weite
    edited November 2024
    I configured it in version 1.21 and there was also the problem.
    Yes, the problem only occurs when I enable the UTM service.
    I'll see what I can do to give you access.
  • Zyxel_Judy
    Hi @weite ,
    For remote assistance, you can send us your TeamViewer or AnyDesk credentials (ID and password) through Community private message.
    Please also indicate your preferred time slot for the session. Our support team is available Monday to Friday, between 1:00 - 9:00 UTC+0.
    We'll connect remotely to help investigate and resolve your issue.
    Zyxel_Judy
    Untitled Image
  • Alexander_Blüthl
    Alexander_Blüthl Posts: 2 image  Freshman Member
    HI, I also experience, that it is not possible to switch on SSL inspection. I tried every possible variant. It seems the feature has a big bug. FW V1.32(ABXF.0)
    Would be nice to know, if anybody has a solution.
  • weite
    We have tested a lot and invested a lot of time, but it still doesn't work. In short, we have given up and trust our antivirus software. No real solution, but we don't have enough time to test the beta product. 😇
