vmg3625-t50b firmware update
eromaba
eromaba Posts: 1 image  Freshman Member
I have home router vmg3625-t50b with current running version V5.50(ABPM.8.1)C0. As there are newer versions 8.3 and 9.2 I was trying to perfpr, upgrade. But I am not able to upload upgrade file (for example VMG3625-T50B_5.50(ABPM.9.2)C0.zip) it always end up with message: Image upload failed…
Do you know what could be the problem?
Thanks,
Roman
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello Roman @eromaba
    Welcome to the forum.
    The firmware, userguide and release notes are at https://www.zyxel.com/uk/en-gb/support/download?model=vmg3625-t50b and it says read the release notes before upgrade.
    The download file is a ZIP archive, so have you unZIPed the archive and selected the firmware file to upload?
    - rather than the release notes or other files that are in the ZIP archive I think.
    I hope that this is helpful.
    Kind regards,
    Tony (a fellow user.)
