802.11r (Apple) client capability not visible anymore in Nebula
2»
  • papu
    papu Posts: 23  Freshman Member
    dear Zyxel, the firmware does indeed seem to reinstate 802.11r, at least for Apple mobile clients. Getting lots of expected fast-roaming messages in the event log. Please allow some more time to test this full 802.11kvr roaming also with other clients, and with connection-sensitive scenarios.
    Thank you very much!
  • Zyxel_Judy
    Zyxel_Judy Posts: 1,584  Zyxel Employee
    Hi there,
    For sure. Please take your time to verify the result.
    Fast-roaming info shows in the Event log as below:
    Share your feedback through our survey, make your voice heard, and win a WiFi 7 AP!
    https://bit.ly/2024_Survey_Community
  • papu
    I can confirm things are ok now (no complaints from staff after change). And assume you already applied this fix to latest release. If so, can you please unlock the firmware upgrade state of my access points? Or explain to me how to do this through ssh cli myself?
  • sanist
    sanist Posts: 4  Freshman Member
    Hi I am running the latest firmware version and am still not seeing the Mobility Domain tags from my NWA50AX. Has the fix been released for GA or is it still beta-only, in which case how could I get access to it?
  • sanist
Nebula Tips & Tricks
