arp spoofing
hello,
yes it is a USG 700 FLEX:
Hi @nicopat,
Thanks for your update. This is more likely because your network has ARP spoofing attacks or IP conflicts. You should check your network first to solve this issue.
If you still want to disable these logs, please reference this comment:
Zyxel Melen0 -
ok, its possible to desactivate the arp spoofing for one interface ?
in my example its for the zone opt
Hi @nicopat,
This command is a global setting command. You cannot disable it for specific interfaces.
Zyxel Melen0
- 441 Beta Program
- 292 Service & License
