FLEX100H no messages sent to syslog server
szn
szn Posts: 20  Freshman Member
edited November 2024 in USG FLEX H Series
I've configured syslog Remote Server. However, no messages is sent to syslog server. Syslog server is accessible from Zyxell. Any suggestion?
firmware V1.30(ABXF.0)
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,526  Zyxel Employee
    Hi @szn,
    Please help to clarify:
    1. What's your setting of "Log Category Setting" for the remote server? The default is disabled for the remote server. image.png
    2. Is the Syslog server in your LAN network, or is it under another public IP? If it is under another public IP, is it behind NAT, and was the NAT rule configured correctly?
    3. Is your Syslog server's setting correctly configured?
    4. Does your Syslog server's firewall block the Syslog service port?
    Zyxel Melen
  • szn
    1. Configured to Normal for all sections
    2. on LAN network
    3. yes, other sources in LAN are working
    4. No.
  • Zyxel_Melen
    Hi @szn,
    I did a local test and my Syslog server could receive logs.
    Here's my USG FLEX H's setting:
    Here's my Syslog server's setting:
    I suggest you can check your configuration again.
    Zyxel Melen
  • Asgatlat
    Asgatlat Posts: 112  Ally Member
    First Comment Friend Collector Seventh Anniversary
    i confirm that remote syslog works for me (i use a synology nas for that)
  • szn
    it is working. it looks like syslog server was the issue. Thx
