USG Flex 200 and Google Authenticator for vpn
13»
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @valerio_vanni
    When using manual configuration, the script will be generated automatically but won't be visible in the local GUI.
    The script is only displayed once - specifically when using the VPN Wizard and immediately after completing the configuration process.
    As for your other question, we've created a new post to better address it. Please continue that discussion in the new thread.
    USG FLEX 200: is 2FA supposed to work on L2TP vpn? — Zyxel Community
    Zyxel_Judy
    Untitled Image
  • valerio_vanni
    valerio_vanni Posts: 157 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    >When using manual configuration, the script will be generated automatically but won't be visible in >the local GUI.
    And it is reachable in other ways? ssh, ftp…
    Or is it hidden forever?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,342 image  Zyxel Employee
    Hi @valerio_vanni,
    Please allow us to rephrase the explanation. The script can only be downloaded via the wizard. The manually configured VPN won't have a script to download. However, you can add this VPN configuration to the "Configuration Provisioning" for SecuExtender to get from the server/firewall.
    In addition, you also can edit the script from the wizard to fit your VPN configuration.
    Zyxel Melen
