FLEX100H no messages sent to syslog server
szn
I've configured syslog Remote Server. However, no messages is sent to syslog server. Syslog server is accessible from Zyxell. Any suggestion?
firmware V1.30(ABXF.0)
Hi @szn,
Please help to clarify:
- What's your setting of "Log Category Setting" for the remote server? The default is disabled for the remote server.
- Is the Syslog server in your LAN network, or is it under another public IP? If it is under another public IP, is it behind NAT, and was the NAT rule configured correctly?
- Is your Syslog server's setting correctly configured?
- Does your Syslog server's firewall block the Syslog service port?
Zyxel Melen0 -
- Configured to Normal for all sections
- on LAN network
- yes, other sources in LAN are working
- No.
Hi @szn,
I did a local test and my Syslog server could receive logs.
Here's my USG FLEX H's setting:
Here's my Syslog server's setting:
I suggest you can check your configuration again.
Zyxel Melen0 -
i confirm that remote syslog works for me (i use a synology nas for that)
it is working. it looks like syslog server was the issue. Thx
- 441 Beta Program
- 210 Nebula Ideas
- 540 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
