obtaining ip address it doesnt connect to device
usman
usman Posts: 19 image  Freshman Member
edited November 2024 in Wireless
is there any issue with vlan configuration? kindly help me resolve this issue
unable to connect any device it just displaying obtaining ip address
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,279 image  Guru Member
    Hi @usman
    To better assist you in resolving this issue, could you please provide more details about your setup?
    1. AP Model and Firmware Version: What is the model of your access point, and which firmware version is it running?
    2. Network Topology: Could you share a network diagram showing your setup? Including the VLAN configuration in this diagram would help us understand your network better.
    3. AP IP Addressing: Is your access point receiving an IP address via DHCP, or is it configured with a static IP?
    4. Connection Issue Details: When you mention being unable to connect any devices, are you referring to client devices failing to connect to the SSID broadcasted by the AP, or are you unable to access the AP itself?
    Your additional information will help us pinpoint the issue and guide you more effectively.
    Looking forward to your response!
    Kay
