firmware download feature is disabled due to ITS installed
Dovetail_MD
USG 60 W says it wants an update and then gives me this notice.
Cloud Firmware
Please note that your new firmware download feature is disabled due to ITS installed. Please contact local support to ensure the upgrade is applicable.
What is ITS in this context?
@Dovetail_MD
If you are running on a firmware version that has specific fix or changing. It will popup certain message to avoid the fix/changing missing after upgrading the firmware. You can cross check the fixes in the release note before deciding if you’re going to upgrade your firmware or not.
Charlie
Thank you Charlie - so I looked at the PDF that was in the zip file I downloaded and had a go.It seems to have partially worked, but then gave me a failure notice so presume it does not like something about this particular box even though it was designed for it0
Charlie - I am sorry I did not take a proper note of it - let us try again
All I got was....Apply 433AAKZ0C0.conf failed and roll back to previous configuration. Please check log for detail information.Log she say "2019-03-19 09:16:56 -info-CAPWAP-Updated Configuration by a WLAN Controller Success. Partial Update0
@Dovetail_MD
What is firmware version of device?
Can you private message the configuration to me for check further?
Charlie0 -
I have sent you a private message
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
